2017-01-18 11:47 PM
I'm developing a customized SPI Bootloader code. I plan to use CRC32 in verifying the programmed application code. I used this link as a reference for my CRC32 calculator C-code function in the Bootloader:
https://github.com/joeferner/stm32-spi-bootloader/blob/master/src/spi-bootloader.c
http://www.ipgp.fr/~tuchais/earthworm/v6.3/src/data_sources/naqs2ew/crc32.c
But, the values that I get when I use that function isn't the same to the ones I get when I load the hex or bin file to ST-Link. ST-Link is showing different CRC32 values.
On the other hand, when I use online tools such as:
http://www.fileformat.info/tool/hash.htm
http://esrg.sourceforge.net/utils_win_up/md5sum/
I am getting the same CRC32 values with my C-code function.
Is ST-LINK using a different algorithm (but in the user manual, it says that it's using CRC32)?
Any insights is appreciated!
Thanks,
#stlink #crc32 #stm32Solved! Go to Solution.
2017-01-23 3:28 AM
Hello
Solomo.Mary_Raullett
,Indeed, ST-LINK Utility is using a different algorithm than CRC32 (to use the algo as STVP too)
The algorithm used in ST-LINK Utility is a simple add operation byte by byte.
Moreover, y
ou are right about the CRC32 algorithm is mentioned in the User Manual as it is supported at first, and then we’ve c
hanged it to much with STVP’s algorithm.
Therefore
, t
he User Manual will be updatedin coming version to add the missed information.
Hope this helps you and thank you for your contribution.
Best Regards
Imen
2017-01-23 3:28 AM
Hello
Moreover, y
Therefore
, t
Best Regards
Imen
