2022-07-18 5:47 AM
Hi
I tried to generate hex2bin crc32 and then crc32 on stm32 (on words, the rest CubeMX configurations were set to default) , but they are not the same. On hex2bin i can configure big or little endianness, but the result doesn't change and i don't know the default.
Did anyone here try to conduct the same experiment and can share the insights or findings?
Thanks!
2022-07-18 6:02 AM
"CRC32" just tells you that the CRC has 32 bits.
You also need to have the same generator polynomial, initial conditions, etc for the results to match.
http://www.ross.net/crc/crcpaper.html
2022-07-18 6:15 AM
Thank you!
Doesn't it also tell the data taken in account is 32 bit?
Will look at your link.
Thank you for your help!
2022-07-18 6:21 AM
@Community member "Doesn't it also tell the data taken in account is 32 bit?"
No - a CRC could be applied to any block of data.
