2023-09-18 11:55 PM
Error in final launch sequence:
Failed to execute MI command:
load D:\\STUSER\\STM32CubeIDE\\workspace_1.13.0\\TEST190923\\Debug\\TEST190923.elf
Error message from debugger back end:
Error finishing flash operation
2023-09-19 11:04 PM
Hi..Am trying your way. Getting same error . Am using Nucleo-H563ZI Board
load D:\\STUSER\\STM32CubeIDE\\GPIO_IOToggle\\Debug\\GPIO_IOToggle.elf
2023-09-19 7:01 AM
Hello @RKOAS
Which board are you using?
Make sure to upgrade the ST Link firmware version, and check SWD/JTAG interface in the debug configuration settings.
Maybe this post helped you: Solved: "Failed to execute MI command.... Load failed.
Imen
2023-09-19 10:05 PM
Thanks for your reply. Am using Nucleo-H563ZI Board. Anyhow I will check the debug configuration settings.
2023-09-19 11:04 PM
