2020-05-29 8:51 AM
Something along the lines of: ./configure CFLAGS="-O2 -mfpu=neon -mthumb -mcpu=cortex-m4" LDFLAGS="--specs=nosys.specs" --host=arm-none-eabi --disable-rtcd --enable-fixed-point
Still having issues with make errors, e.g.,
celt_pitch_xcorr_arm-gnu.S:547: Error: thumb conditional instruction should be in IT block
2020-05-29 9:32 AM
Determine if the assembler source file contains any conditional assembly code, and what command line defines those would need, or if you need to find a different source file for the Cortex-M devices.
