2021-01-11 2:23 AM
I have a custom board with SWO pins for STM32 firmware (but I don't have the RESET pin)
I was planning to update my board remotely with ST-Link and raspberry pi
But I found out too late that STM32CubeProgrammer does not support ARM
I tried to use ST-Link Utility but couldn't work it with Soft Reset
Is there a way out? I don't want to order a new board
2021-01-11 7:50 AM
Should be possible using OpenOCD from sources for Raspi like here: https://iosoft.blog/2019/01/28/raspberry-pi-openocd/
2021-01-11 8:44 AM
Perhaps you can just add code to your own firmware (loader+app) so it can update itself rather than relying on SWD/JTAG or the System Loader.
ie some sort of IAP / FOTA type affair, where you control ALL the variables, and can write code for whatever platform you choose.
