2011-01-21 11:18 AM
Timer update event interrupt retriggering after exit.
2011-05-17 5:22 AM
Great! Thank you for the thorough explanation. Would it be possible to put this level of detail in the technical manual?
Mark
2011-05-17 5:22 AM
Hi Mark,
I just found a similar explanation in the FAQ./FAQ/Lists/faqlist/DispForm.aspx?ID=144
2014-07-02 2:19 AM
The relevant faq entry has been moved:
https://my.st.com/public/Faq/Lists/faqlst/DispForm.aspx?ID=1432014-07-02 4:26 AM
As a clickable link
I'll note that the suggestion to use bit-banding is probably a bad one, and particularly dangerous for TIMx->SR cases as it's only atomic from the processors perspective. It can result in dismissing interrupts that pend in the 4 or whatever cycles between the read/writeWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
