2016-03-31 6:49 AM
Hello ,
I have config to TIM8 to generate 12 MHz clock signal on PC8 using Timer8 Channel . For this I have configured as per below . When I checked on DSO , I am not getting any signal . What could be the reason for this ? int main(void) { /* TIM Configuration */ TIM_Config(); /* TIM clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE); /* Time base configuration */ TIM_TimeBaseStructure.TIM_Period = 6 ; //for 2.048 MHz ---> use 40; TIM_TimeBaseStructure.TIM_Prescaler = 0; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure); /* PWM1 Mode configuration: Channel1 */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC3Init(TIM8, &TIM_OCInitStructure); TIM_OC3PreloadConfig(TIM8, TIM_OCPreload_Enable); TIM_ARRPreloadConfig(TIM8, ENABLE); TIM_CtrlPWMOutputs(TIM8, ENABLE); /* TIM8 enable counter */ TIM_Cmd(TIM8, ENABLE); while (1){} } void TIM_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; /* GPIOC and GPIOB clock enable */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC , ENABLE); /* GPIOC Configuration */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 ; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ; GPIO_Init(GPIOC, &GPIO_InitStructure); /* Connect TIM8 pins to AF2 */ GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_TIM8); } #output #timer #pwm #stm32f4 #discovery2016-03-31 8:09 AM
int main(void)
TIM_Config();
TIM_TimeBaseStructure.TIM_Period = (SystemCoreClock / 12000000) - 1; // 12 MHz
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
/* PWM1 Mode configuration: Channel3 */
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disble;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
while (1){}
GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_TIM8); // PC8 TIM8_CH3
2016-03-31 10:46 PM
Clive1 ,
Thanks for reply but I am not getting output signal on PC8 . (1) I have verified - PC8 is only configured TIM8 , Channel 3 in our code . (2) What else could be reason for not getting output signal ?2016-04-01 10:14 AM
Seemed to be viable here, I cleaned it up a little more and just bench tested this to confirm I can see 6 MHz (12 MHz toggle rate). If you don't check you are look at the right pin, or that there isn't something else going.
/* GPIOC clock enable */
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_25MHz; // 2,25,50, or 100
int main(void)
TIM_OCInitTypeDef TIM_OCInitStructure;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_Config();
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle; // 6 MHz output
TIM_OCInitStructure.TIM_Pulse = 0;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;
while (1){}
2016-04-03 10:57 PM
clive1 ,
Scope is connected at proper MCU pin only .Need help further from your side . I have attached system_stm32f4xx.c and startup_stm32f4xx.s file . Please give a one look and let me know what could be wrong with this set up . ________________ Attachments : startup_stm32f4xx.s : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzo3&d=%2Fa%2F0X0000000bbl%2FWWcIo.34SJ.IvYoFotDjaTwV83X_lxkrMHCtP40_04E&asPdf=falsesystem_stm32f4xx.c : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0dZ&d=%2Fa%2F0X0000000bbj%2FeNB2mWzRvKcYxxLpNeeO00zNveOnGvJ9t7n6qjYImNc&asPdf=false2016-04-04 3:30 AM
Confirm that the code is running in a debugger. I tested functionality on STM32F4-DISCO
2016-04-05 10:38 PM
clive1 ,
In TIM_OC3Init() , /* Set the Capture Compare Register value */ TIMx->CCR3 = TIM_OCInitStruct->TIM_Pulse; line was creating issue . So that CCR3 has initialized to some other value . After this if we assign value less than 3000 ,timer clock was not generating . Fills each TIM_OCInitStruct member with its default value. TIM_OCStructInit(TIM_OCInitTypeDef* TIM_OCInitStruct) needs to used before TIM_OC3Init() API . The code that you have given was working with Keil IDE while it was not working with gcc tool-chain. Any idea about this ? - Pinkesh2016-04-06 6:37 AM
Hi pinkesh,
Please, give us more details about the device/hardware your using , the system clock configuration ... -Hannibal-2016-04-06 7:02 AM
Hi pinkesh,
Try to copy and paste code in the main.c file of a template project in the STM32 standard library and it will work fine ( I have tested it with ST' gcc compiler system workbench SW4STM32). Maybe you have some extra code lines that makes problem with gcc. -Hannibal-2016-04-06 8:06 AM
I don't know, and really can't throw resources at it, it works here, the structures are fully initialized. Perhaps you can use PWM mode, and program with a 50/50 duty?
What version of GNU/GCC, some have given me headaches in the past (4.9) where viable code has been broken by the code generator/optimizer.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
