2020-04-01 5:13 AM
I need to change the dead time of the TIM1 complementary outputs cycle by cycle. What is the behavior if I just overwrite the DTG[7:0] value during a cycle: does it change the actual dead time of the next cycle? or the current?
Thank you in advance.
2020-04-02 3:02 AM
As long as no locking is set, the reference manual implies that you can change the DTR value.and that should have an effect!
