2024-06-17 3:23 AM - last edited on 2024-06-25 9:35 AM by Andrew Neil
We are using STM32G070RB for our application. Need a reference design for the schematic & also as mentioned in below screenshot there is requirement of L1 inductor on AVDD pin, Please let me know the Required value of inductance/impedance or please suggest suitable part no.
Also can we connect VBAT to VDD?
2024-06-17 3:59 AM
Review AN5096.
There's no AVDD pin on this mcu, and VDDA is internally connected to VDD.
You may be talking about VREF+; if you want to supply that from VDD/VDDA, basically you want to create a low-pass filter to filter out all the digital noise; but there is no single good design/value/model/make for it. You may have a look at the related 'G0 DISCO/EVAL board how is this detail solved there.
2024-06-17 4:18 AM
@waclawek.jan wrote:You may have a look at the related 'G0 DISCO/EVAL board how is this detail solved there.
Although the Disco boards are not necessarily optimised for best analogue performance ...
