2016-08-27 5:51 AM
Since ST have consistently failed to fix the synchronous memory read bug, I am thinking about using async access to an FPGA, with continuous clock FMC_CLK.The ST datasheets give no timing info at all in this regardThe async control signals will follow HCLK or FMC_CLK, but is there any additional data?Also is the FMC_CLK **always** enabled (i.e. can I clock the FPGA PLL from it) The datasheets are unclear about this,Thanks!We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
