2013-07-21 9:42 AM
2013-11-17 6:13 PM
Kocsis.jeno,can you send me the correct code? thank....
2014-07-12 6:32 AM
Hello
Is it possible for you to send your completed code?How do you display images that you have uploaded here ? Thanks.2015-04-11 11:01 PM
Hello
How do you see your captured pictures in pc or your laptop?Any specific software do you use?Thanks.2015-04-22 7:16 AM
Hello
I can write to registers but can't read them, what is the reason?I supply xclk pin with 42MHz sysclk coming from MCO2.Thanks.2015-05-12 3:23 AM
could you please send me the complete code for me?
it will be very helpful for me2015-06-28 7:27 AM
Hello
My problem was solved, unfortunately it was related to stm32cubef4 software package.2015-07-04 6:13 PM
Hello
I have some questions about this module:What is the ov7670 output format in test pattern mode?Is it configurable?which registers should be configured for this mode?What is the application of HSTART, HSTOP, VSTART and VSTOP registers?Thanks.2015-07-05 8:06 PM
This would be useful for you.
OVM7690 1/13�? VGA CameraCube Camera Module Software Application Note OV7670 Dual Camera Module Application Notes2015-07-25 2:35 AM
2015-07-25 2:43 AM
Hi now i am able to get the image.
I want to implement UVC class with my camera, I have written the code also , the PC recognised my board as an imaging device .
But the problem is in isochronous transfer in high speed mode .I m not getting anything while transferring the data.
Can anyone help me ?
