2019-08-16 3:27 AM
In the STM32F446xC/E datasheet, DocID027107 Rev 6, footnote under Table 11. Alternate function says:
1. The DCMI_VSYNC alternate function on PG9 is only available on silicon revision 3.
However, neither DBGMCU_IDCODE description in RM0390 Rev 4, nor STM32F446xC/xE
Errata sheet DocID027362 Rev 2 recognize "silicon revision 3", both mention only revision A.
ST, can you please clarify?
Thanks,
2019-08-29 3:46 AM
Hello @Community member ,
This footnote is wrong and it should be removed from the datasheet.
This is highlighted internally for correction.
Thank you for bringing this to our attention.
Best Regards,
Imen
2019-08-30 12:04 AM
Thanks, Imen.
Jan
