2025-01-07 3:07 PM
I want to ask what is necessary for implementation of 32.768khz RTC XTAL to STM32F411CEU6?
In AN3060 I saw in chapter 3, fig6 that external load caps are not needed because they are implemented in STM32 MCU. Then I checked STM32F411CEU6 datasheet and there is figure25 where is example that resonator have these caps in the package.
What is correct? Provided information in ST documents quite confused me.
I have this XTAL - ABS06-32.768KHZ-1-T
Thank you for your advide.
Regards,
Martin
2025-01-07 3:30 PM - edited 2025-01-07 3:33 PM
Isn't that APP NOTE for a COMPLETELY different series of stand-alone RTC?
Pretty sure you want a 6-7pF 32.768 KHz crystal with load capacitors on the STM32F4
AN2867 is for the STM32's
2025-01-07 3:33 PM
ABS06-32.768KHZ-1-T is a 12.5pF crystal, I'd not be using that for F1/F2/F4 devices.
ST has example designs in the form of DISCO and EVAL boards, go the the web pages for the products, under the "CAD Resources" tab you can find schematics and BoM
2025-01-07 3:36 PM
https://stm32-base.org/boards/STM32F411CEU6-WeAct-Black-Pill-V2.0.html
https://stm32-base.org/assets/pdf/boards/original-schematic-STM32F411CEU6_WeAct_Black_Pill_V2.0.pdf
