2025-01-21 2:14 AM - last edited on 2025-01-21 2:25 AM by Andrew Neil
when I use the usart6's DMA, my SDIO can't write to the SD card properly
2025-01-22 2:12 AM
What, exactly, don't you understand?
You'll need to give a lot more detail for people to be able to help you - see: How to write your question to maximize your chances to find a solution
Or, if you're happy that the problem is solved, just mark your previous post as the solution:
https://community.st.com/t5/community-guidelines/help-others-to-solve-their-issues/ta-p/575256
2025-01-22 2:20 AM
why usart6'dma must use the FIFO mode. if I not use ,the data recived by usart6 is whole,then I write to the SD,the data in SD is loss
2025-01-22 2:27 AM
Again, you'd need to give more details.
You haven't shown any code - so impossible to know where the mistake might be.
Instrument your code so that you can see what's going on in both the working and non-working cases.
Compare & contrast.
Look into where & when this "loss" occurs
Use a logic analyser on the SDIO to see what's actually happening in the hardware
