2015-12-16 1:04 AM
hi i'm new here
i juste start with STM32-P207 board, i need to use temperature sensor in board, it connect with PG12 & PG10, but i dont find in Alternate function mapping that PG12 & PG10 are mapping in I2C Any help please !Solved! Go to Solution.
2015-12-16 4:50 AM
First, download STMCubeMx, select your board, and you will know what you can use for what interface.
If you don't have AF , just use different pins that does !2015-12-16 4:50 AM
If you don't have AF , just use different pins that does !We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
