2019-05-20 1:59 AM
I use STM32F205ZGT6 for our product.
In our design, PH10 and PH11 is connected external module. When external connected, the port get physical damage in only revision V. I checked that the other revision such as 1 , 2 and 3 don't have same issue.
I set PH10 and PH11 port as alternate function, Open-drain, Pullup and Active Low.
I hope to know this issue is reported or not to STM and what differ between revision V and others.
There are no mention about this issue in errata sheet.
2019-05-24 6:02 AM
Hello @CLee.5.54 ,
As there is no particular issue already known for STM32F205ZGT6 rev V, the problem you are reporting needs to be investigated.
So, could you please
Thanks,
Amel
2019-05-26 8:51 PM
2019-05-27 5:58 AM
Hi Chikang,
The attachment is well received. It will be reviewed by our experts.
Would it be possible to complete the marking of other devices (rev V)?
Thanks,
Amel
2019-05-31 2:23 AM
Hi Amel,
There are markings of MCU below. "8" and "B" are confusing when i read those. Looks very similar.
STM32F205ZGT6 7B227 VG PHL 7B811
STM32F205ZGT6 7B483 VG PHL 7B723
STM32F205ZGT6 7B836 VG PHL 7B713
STM32F205ZGT6 7B242 VG PHL 7B812
Thanks you
