2014-10-25 12:56 AM
Hello is possigle and problem free use serial SPI
http://www.st.com/web/en/resource/technical/document/datasheet/CD00001441.pdf
with signal CS direcet on GND? Of course EEPROM is alone on this SPI bus.2014-10-25 5:56 AM
''After power-up, a falling edge on Chip Select (S) is required prior to the start of any instruction.''
