2018-05-18 7:09 AM
Hello, in these days I'm using for the first time Stm32CubeProgrammer and I notice a little problem in version 1.0.0: In the page 'Erasing & Programming' the button 'Browse', used to select the directory where find the .Hex to use in order to program the device doesn't work. Is there any new Softeware version or way to solve the issue?
Thank you
DamianoSolved! Go to Solution.
2018-05-21 12:37 AM
Hi
Gilioli.Damiano
,This issue will be fixed in version 1.1.0
As a workaround ,please delete the following file:
c:\Users\%USERNAME%\STMicroelectronics\STM32CubeProgrammer\config.properties
Khouloud.
2018-05-18 7:30 AM
Looks similar?
2018-05-18 10:36 AM
Yes, but I'm able to perform the device program because I write (by hand...) the full path in the related window
2018-05-21 12:37 AM
Hi
Gilioli.Damiano
Khouloud.
