2018-05-17 3:25 AM
I tried to compile the 'Hello World' example provided in stm32cube F7 package, with no success.
I copied all files from STM32Cube_FW_F7_V1.11.0/Projects/STM32746G-Discovery/Applications/STemWin/STemWin_HelloWorld/Core and STemWin/ foldersand tried to compile, with correct link flags.
I get errors:pio_builds/disco_f746ng/src/stm32f7xx_it.o: In function `SysTick_Handler':
stm32f7xx_it.c:(.text.SysTick_Handler+0x10): undefined reference to `OS_TimeMS'/.../Middlewares/ST/STemWin/Lib/libSTemWin540_CM7_GCC.a(GUI_Core.o): In function `GUI_Init':GUI_Core.c:(.text.GUI_Init+0xbc): undefined reference to `GUI_X_Init'I added the 'lib-' prefix to the library and included following flags to gcc:
-I/home/jure/Projects/ARMdev_stuff/STM32Cube_FW_F7_V1.11.0/Middlewares/ST/STemWin/inc
-L/home/jure/Projects/ARMdev_stuff/STM32Cube_FW_F7_V1.11.0/Middlewares/ST/STemWin/Lib
-lSTemWin540_CM7_GCC
-lSTemWin540_CM7_GCC_ARGB
-lSTemWin540_CM7_GCC_ot
-lSTemWin540_CM7_GCC_ot_ARGB
mfloat-abi
=hard
mfpu
=fpv5-sp-d16
I am using STM32F7 discovery board, stm32cube framework (HAL) and no RTOS or anything.I didn't change any code in the Hello World example, which is written exactly for this platform. What should I do?Solved! Go to Solution.
2018-05-17 4:08 AM
Hello
vidmarjur
,Have you copiedthe
fileGUI_X.c?
You should copy the
GUI_X.c file
$Library_path\STM32Cube_FW_F7_V1.0\Middlewares\ST\STemWin\OS\GUI_X.c
to folder
‘\Src’in root of your project.
With Regards,
Imen
2018-05-17 4:08 AM
Hello
vidmarjur
,Have you copiedthe
fileGUI_X.c?
You should copy the
GUI_X.c file
to folder
With Regards,
Imen
2018-05-17 7:23 AM
Yes, this resolves the issue!
How come that this file is not already in src/ folder of the given Hello World example? o.0Documentation (Getting started with STemWin) didn't mention that it's necessary to include GUI_X.c explicitly.Well, however it compiles now.Thank you for your help and time !We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
