2016-02-09 10:53 PM
Hi dear members,
I want to interface jhd12864 lcd using Stemwin library, The segger document says that you can configure the KS0108 driver in the run time using GUIDRV_SPage.
But GUIDRV_SPage.h file is not included in Stemwin distribution..Please help me out in this.
2016-02-10 9:07 AM
Similarly, working with STMCube_FW_L1_V1.40, STemWin version 5.28 is included. The documentation states that run-time configurable driver GUIDRV_SPage is included.
However, there is no GUIDRV_Spage.h file in the document tree Middlewares\ST\STemWin. There is no prototype for run-time configuration GUIDRV_SPage_Set1502().It appears that the STemWin included in STMCube L1 is incomplete.2016-02-25 11:49 AM
Required drivers for use with STemWin can be purchased from SEGGER for $$$.
2016-09-12 4:46 AM
In the manual, the driver is described. In that case, in my understanding, it should be included!!!!!!!!!!!!!!!
Same problem!2016-09-14 8:36 AM
Hi metzger.marco,
Could you please precise which controller and firmware version are you using ?You can check in the emwin user manual (or through this ) if your display controller is supported by GUIDRV_SPage driver. RegardsWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
