2010-08-18 5:25 AM
SPI serial flash and DMA transfer
2011-05-17 5:03 AM
2011-05-17 5:03 AM
Thankyou for answer, I have corrected this mistake but without any changes :(
2011-05-17 5:03 AM
Hi tom.f,
were you able to find a solution to this problem.
I am seeing a similar problem with my system, where at random, values read from the SPI flash using DMA are zeros.
To be more specific, I have a flash file system and when a file is readout, sometimes there is a block of zeros in the read out data.I know that the file data in flash is good and the read will be successful if I try to read again.
