2012-03-29 1:16 AM
2012-03-29 7:00 PM
Just make sure that the circuit is not drawing too much current.. for example LCD backlight ..
or SPI pins accidently/momentatrily shorted to VDD/Gnd. causing the 3.3V to drop...Ths may cause the Debugger to fail. I guess you may have verified that the board is fine by running another firmware2012-03-29 8:23 PM
Failed to read CPUID for Cortex device
> It seems like JTAG works fail. I suggest check the setting of your J-Link. Can you post more fail information?SimonWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
