2015-10-07 5:20 AM
Does
anyone know
how to install a
software expansion package for STM32Cube. Let's say I downloadedX-CUBE-MEMS1
.ZIP. I then went to ''Help/Install New Libraries'' then clicked on ''From Local...'' I selected the downloaded zip file. I got an error message : This Package version is not managed on this version of STM32CubeMX. What is wrong ? Regards2015-10-09 3:19 AM
Hi pipon.herve.001,
X-CUBE-MEMS1 is a software expansion for STM32Cube (driver) and not STM32CubeMx (a graphical software configuration tool that allows generating C initialization code).
So you do not have to install it through STM32CubeMx. For more details, please have a look athttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00157069.pdf
. -Shahrzad-Hello,
Does
anyone know
how to install a
.ZIP. I then went to ''Help/Install New Libraries'' then clicked on ''From Local...'' I selected the downloaded zip file. I got an error message : This Package version is not managed on this version of STM32CubeMX. What is wrong ? Regards2015-10-12 4:18 AM
Hi shahrzad,
Thanks for this information, I ignored there was two versions of STM32Cube Best Regards2016-08-22 6:47 AM
From the document (UM1859) you mentioned it's not clear how the downloaded package file 'en.x-cube-mems1.zip' for this library should be installed. Is there a particular location that the folder that the folder inside this archive file should be placed?Regards,Hugh J.2016-08-22 7:21 AM
You can download the X-CUBE-MEMS1 package from this RegardsWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
