Sigfox_Button example in STSW-S2LP-SFX-DK. Hi I tried to test a custom board (STAM32L073 and S2-LP) using the Sigfox_Button example code. The program gets stuck when I try to send a message. Above I describe the details.
trx2001
Associate II
I changed the pins appropriately in order to adapt the example to the test hardware.
I also stored sigfox ID and PAC in the STM32 flash. The Initializations appear to be successful. Unfortunately when I try to send a message to the Sigfox backend via:
SIGFOX_API_send_frame(customer_data,4,customer_resp,2,0);
the program remains locked on this call forever.
Unfortunately, having no return codes, I am unable to understand the nature of the problem. Is there anyone who has had the same kind of problem and can you help me?
Thanks in advance
Adriano
0 REPLIES 0
