2013-12-26 9:07 PM
Guys,
Does anyone know on how to initialize RTC on STM32 and display the content of the register to LCD ? Any links or reference will be appreciated, Thank you #think!2013-12-27 2:09 AM
''Does anyone know on how to initialize RTC on STM32''
Which STM32?Have you studied its Documentation?Have you looked at the examples included in the Standard Peripheral Library?eg,STM32F37x_StdPeriph_Examples\RTC''display the content of the register to LCD''What LCD?In what form do you want to display it?The fact that it happens to be a value from the RTC is irrelevant to the LCD...
2013-12-27 8:04 AM
STM32F107 and LCD 20x4.....
2013-12-27 10:54 AM
Well that answers, ''which STM32?'' and is a partial answer to, ''What LCD?''
So what about the other questions:Have you studied its
Documentation?
In what form do you want to display it?And it remains that the fact that it happens to be a value from the RTC is irrelevant to the LCD...
Which STM32? Have you studied its Documentation? Have you looked at the examples included in the Standard Peripheral Library? eg, STM32F37x_StdPeriph_Examples\RTC''display the content of the register to LCD'' What LCD? In what form do you want to display it? The fact that it happens to be a value from the RTC is irrelevant to the LCD...
2013-12-27 10:55 AM
2014-01-04 3:06 PM
I can display some strings already in LCD and display RTC on USART,
My question is, how to use a variable on USART and display it on LCD ? code : printf(''Time: %d-%d-%d %02d:%02d:%02d \r\n'', time.tm_year, \ time.tm_mon+1, time.tm_mday,\ time.tm_hour, time.tm_min, time.tm_sec); sprintf(year,''%02d'',time.tm_year); lcd_string(time.tm_year); another reference that I can consider : http://www.st.com/st-web-ui/static/active/jp/resource/technical/document/application_note/DM00025071.pdf2014-01-06 3:54 PM
The golden rule of software development is: Divide and Conquer - ie, break the problem down until you reach smaller problems which are easily solved.
In this case, you have two independent ''problems'':1. Converting data - of whatever form, from whatever source - into a string format;2. Outputting an arbitrary string - irrespective of its content or source - to your chosen peripherals (UART, LCD, whatever,...)2014-01-07 2:39 PM
Another thread on the same topic:
http://goo.gl/w27Y72
2014-01-07 9:30 PM
2014-01-07 10:29 PM
