2016-04-18 10:00 PM
Hi, one of our project we are using stm32l053 and using HAL driver for accessing peripherals, i have read the single ADC channel (ADC channel 13)successfully, but i was unable to read multiple channnel at same time.
Any one can share the sample code to read ADC multiple channel using polling method. Regard MK2016-04-19 2:19 AM
For multiple channel, you need to use DMA.You can refer to the RM0377 (13.6.5 Managing converted data using the DMA)http://www2.st.com/content/ccc/resource/technical/document/reference_manual/21/bd/0f/bd/1c/88/40/f0/DM00108282.pdf/files/DM00108282.pdf/jcr:content/translations/en.DM00108282.pdfIn this reference manual, you can find Appendix A8 ADC Code examples (page 827) that can help you.In the section (10.3.7 DMA request mapping) the ''table 48'' lists the DMA requests for each channel: Table 48. Summary of the DMA requests for each channel (page 246)You should be able to identify the free/usable pins, as given in section ''13.12.12 ADC register map''Regards2016-04-19 6:39 AM
Hi ,
Thanks for your information,let me check and let you know.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
