2026-03-19 1:38 AM - last edited on 2026-03-19 2:07 AM by mƎALLEm
Should each vdd pin of the stm32f407zgt6 read continuity like the blue pill on multimeter, are they internally connected within the chip or separated? Similary for all the vss pins are they also all connected vss inside stm32f407zgt6
Thanks
2026-03-19 4:10 AM
Your response is philosophical!
I understand the first paragraph bit the second paragraph is confusing. I will try and simply follow the datasheet and Application note.
2026-03-19 4:10 AM - edited 2026-03-19 4:46 AM
@OLAMIDESET wrote:
Yes I will but can you please provide a screenshot of the vdd pins that read continuity and vss pins that beep continuity on free stm32f407zgt6 chip? Thanks
Sorry I cannot do that. I don't have that MCU part number.
The previous answer is generic and applies to all STM32 and the test I did is done on another MCU part number.
Thank you for your understanding.
2026-03-19 4:20 AM
@OLAMIDESET wrote:I will try and simply follow the datasheet and Application note.
That's always the best way!
2026-03-19 4:31 AM
@OLAMIDESET wrote:the second paragraph is confusing.
In what way(s) ?
