2010-07-29 5:39 AM
Problem with I2C master received 4 bytes
2011-05-17 5:00 AM
You are right, I use an I2C Slave which don't allow the multiple read. Thanks.2011-05-17 5:00 AM
I think the problem is with the I2C slave. If I try with the EEP of the STM3210C-EVAL all is right. So I look for a solution in the I2C slaveWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
