2014-08-21 1:02 AM
i am facing problem for the PiD controller.what parameter i have to use it for the positive & negative nos for calculation purpose.Kindly look following code New_Duty_cycle_buck=(Previous_Duty_cycle_buck + Error_Duty_cycle_buck);where ''Error_Duty_cycle_buck'' can be positive or negative.it is for the updating a new duty cycle.in declaration part,double Error_Duty_cycle_buck=0;i declare like this.but my pid loop not working correctly.pls helpLook forward to hearing you soon. #stm32f4 #discovery
2014-08-21 7:50 AM
That is more of a P controller algorithm with kP=1, and not PID....but my pid loop not working correctly.
Hard to judge, you did not present any 'pid loop' code.
2014-08-21 9:54 AM
Not very good at explaining problems. [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Problem%20in%20duty%20cycle&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=38]https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2Fcortex_mx_stm32%2FProblem%20in%20duty%20cycle&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=38
Do the math, print out the results to the console, and also try with PC based C code emulating the loop and the values you expect to read. Once you have modeled it correctly apply it to hardware, and the value read there.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
