2015-03-16 8:53 AM
2015-03-16 9:03 AM
Is there something I should be doing differently?
The 10X scope probe?2015-03-16 9:11 AM
Perhaps the PCB layout ? Signal propagation is not only a matter of your source (SPI pins), but also of the complex impedance your wiring represents. Perhaps the PCB tracks (or wires) too long, and don't match source/sink impedance ? PCB layout for HF signals is not a trivial matter. There are a lot of open designs available you can use as reference, such as ST's Discovery boards - at least in regard to PCB routing. Edit: And yes, clive is correct. A scope probe already represents a high capacitive load, a could impair the signal significantly.
2015-03-17 6:44 AM
What is the bandwidth of your oscilloscope?
2015-03-17 1:54 PM
2015-03-18 6:03 AM
