2019-01-17 12:18 AM
Hi everyone:
We tried the MCSDK and deployed it in stm32f407. But we got a problem, for example:
2019-03-06 9:33 AM
Dear James,
Sorry for the delay.
Your issue is reproduced, and will be fixed in the next release.
You can already test it by commenting the line 205 of the file hall_speed_pos_fdbk.c :
// pHandle->ElSpeedSum = 0;
Let me know if it does the job.
Cedric
2019-01-18 6:29 AM
Hello James,
Are you using the STM3240G-EVAL from ST or some custom board?
Can you please also indicates which SDK version you are using?
It should help us to reproduce your problem.
Thanks,
Claire
2019-01-20 5:27 PM
Hello Claire,
We are using the STM32f4Discovery and IHM08m1 3Sh from ST. And the problem also appear in the combination of Nucleo-F302R8 and IHM08m1 3Sh. We've used SDK 5.12, 5.20 and 5.32, they have the same results.
Thanks,
James
2019-01-21 4:20 AM
Dear James,
Could you confirm that your issue appears only when you start your motor from a non zero speed ?
Could you describe your configuration : are you sensorless ? Do you use an encoder or a hall sensors ?
when your issue appears, what is the speed indicated by the WB ? Are you able from this stage to stop the motor and to re-start after a 0 speed into a correct state ( correct speed )
Did you enable the On the fly parameter in the Workbench ?
Cedric
2019-01-21 5:52 PM
2019-01-22 12:43 AM
Dear James,
Thank you for the information.
We will try to reproduce your issue and keep you aware of our findings.
Cedric
2019-02-10 7:11 PM
Hi Credric,
Is our issue can be reproduced?
Thanks,
James
2019-03-06 9:33 AM
Dear James,
Cedric
2019-03-18 10:55 PM
Hi Credric,
This fix can work well and helpful.
Thanks,
James
