2012-10-05 12:44 PM
Hi All,
The compiler I am using: + STM32F4xx_DSP_StdPeriph_Lib_V1.0.1I am just getting started with STM32F4-DISCOVERY and I have a blinking LED, but I set up everything manually (no CMSIS or standard peripheral library). I followed a number of online sites to setup CMSIS + StdPeriph in eclipse but I always run into the same problem: Ther eis no ARMCM4.h or system_ARMCM4.h. Where can I get these?Does anyone have any good resources on using these libraries with GNU toolchains and eclipse? Thanks for the help!Sam2012-10-07 9:07 PM
I built both versions of the DSP library with GNU/GCC under Yagarto.
[DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Building CMSIS DSP_LIB for GCC&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=235]https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2Fcortex_mx_stm32%2FBuilding%20CMSIS%20DSP_LIB%20for%20GCC&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=235 If you need the CMSIS files, you can always download them from the source.http://www.onarm.com/cmsis/download/
