2020-03-12 8:10 AM
For a project, I am using the code given on the STLRWAN1 web page (https://www.st.com/en/evaluation-tools/i-nucleo-lrwan1.html#tools-software), and the project "End Node". I am using the L476 uC and the SX1272. How can I configure the code in order to make the antenna works on PA BOOST ? The original code makes the antenna works on RFO.
Thanks.
2020-03-12 8:59 AM
You presumably take your sx1272mb2das.c or equivalent file driving YOUR SX1272 implementation, and modify the SX1272GetPaSelect() routine to pick a different output pin.
uint8_t SX1272GetPaSelect( uint32_t channel )
return RF_PACONFIG_PASELECT_RFO;
or
uint8_t SX1276GetPaSelect( uint32_t channel )
if( channel > RF_MID_BAND_THRESH )
return RF_PACONFIG_PASELECT_PABOOST;
else
2020-03-12 8:59 AM
or
else
2020-03-13 1:41 AM
Thanks for the quick answer, I really appreciate it.
I changed the function SX1272GetPaSelect like you said, but when I read the register 0x09 (RegPaConfig), the value is still 0x0F, so PaSelect is still configured on RF0.
I tried to write directly the good value (0x8F) in the register 0x09, it works, but after the LoRa.Join() function, the value is reset to 0x0F.
Any idea ?
Thanks.
2020-03-13 3:29 AM
Found the solution, there was a problem in the configuration of my SPI, thanks for your help !! :)
2020-03-24 8:58 AM
Is is useless to open a discussion only for that question, but do you know a way to get the time and date of the LoRa server after the JOIN request ?
Thanks
