2021-03-08 3:52 PM
I use STM32L496RGT6 with own bootloader.
If I start IWDG in bootloader and periodically reset it it is work good. If I jump to application and call HAL_IWDG_Refresh(..), function doesn't refresh IWDG and IWDG reset mcu.
I tried call MX_IWDG_Init() after HAL_IWDG_Refresh.. or only HAL_IWDG_Refresh but doesn't have effect.
Please help how to resolve this problem. I would like start IWDG in bootloader end periodically refresh it, after jumping into application fw continue refreshing IWDG counter if it is possible.
Thank you,
best regards
2021-03-08 5:06 PM
Are you sure it does not time out before you succeed to call it for the first time in the application?
Toggling a pin around the refresh call, and observing it using oscilloscope/logic analyzer would reveal if this is the case.
2021-03-08 5:06 PM
