2021-02-10 7:58 AM
is here a way to toggle a GPIO pin if a timer detects a 300us dead time in a continous/clock signal?
If so, how? I would like to use a timer only, so no "individual" coding, just CubeMX configuration.
2021-02-10 8:22 AM
Route your signal to timer TIMx_ETR pin. Configure timer to combined reset + trigger and one-pulse modes. Configure an output compare channel to toggle (or maybe PWM 2) mode and set it to the desired dead-time.
2021-02-11 12:35 AM
Hey, thanks a lot! I will try that!
