2016-05-10 2:41 AM
Hi!
I want to use DAC generating Sine wave. But I don't understand why I need '' static'' key in the functionstatic void
TIM6_Config(void
static
void
DAC1_Config(void
);If I delete static, Sine wave do not creat. :( I need some explanation about static function and Timer trigger in STM32. this is my full code:
&sharpinclude <stm32f4xx.h>
&sharpdefine
OUT_FREQ 5000//
Output waveform frequency
&sharpdefine
SINE_RES 128//
Waveform resolution
&sharpdefine
DAC_DHR12R1_ADDR 0x40007408//
DMA writes into this reg on every request
&sharpdefine
CNT_FREQ 42000000//
TIM6 counter clock (prescaled APB1)
&sharpdefine
TIM_PERIOD ((CNT_FREQ)/((SINE_RES)*(OUT_FREQ)))//
Autoreload reg value
const
uint16_t function[SINE_RES] = {2048
,2145
,2242
,2339
,2435
,2530
,2624
,2717
,2808
,2897
2984
,3069
,3151
,3230
,3307
,3381
,3451
,3518
,3581
,3640
3696
,3748
,3795
,3838
,3877
,3911
,3941
,3966
,3986
,4002
4013
,4019
,4020
,4016
,4008
,3995
,3977
,3954
,3926
,3894
3858
,3817
,3772
,3722
,3669
,3611
,3550
,3485
,3416
,3344
3269
,3191
,3110
,3027
,2941
,2853
,2763
,2671
,2578
,2483
2387
,2291
,2194
,2096
,1999
,1901
,1804
,1708
,1612
,1517
1424
,1332
,1242
,1154
,1068
,985
,904
,826
,751
,679
610
,545
,484
,426
,373
,323
,278
,237
,201
,169
141
,118
,100
,87
,79
,75
,76
,82
,93
,109
129
,154
,184
,218
,257
,300
,347
,399
,455
,514
577
,644
,714
,788
,865
,944
,1026
,1111
,1198
,1287
1378
,1471
,1565
,1660
,1756
,1853
,1950
,2047
static
void
TIM6_Config(void
static
void
DAC1_Config(void
int
main(){ GPIO_InitTypeDef gpio_A; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE); gpio_A.GPIO_Pin
=GPIO_Pin_4; gpio_A.GPIO_Mode
=GPIO_Mode_AN; gpio_A.GPIO_PuPd
=GPIO_PuPd_NOPULL; GPIO_Init(GPIOA,
&gpio_A); TIM6_Config(); DAC1_Config();
while
(1
static
void
TIM6_Config(void
){ TIM_TimeBaseInitTypeDef TIM6_TimeBase; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE); TIM_TimeBaseStructInit(
&TIM6_TimeBase); TIM6_TimeBase.TIM_Period
=(uint16_t)TIM_PERIOD; TIM6_TimeBase.TIM_Prescaler
=0
; TIM6_TimeBase.TIM_ClockDivision
=0
; TIM6_TimeBase.TIM_CounterMode
=TIM_CounterMode_Up; TIM_TimeBaseInit(TIM6,
&TIM6_TimeBase); TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update); TIM_Cmd(TIM6, ENABLE);}
static
void
DAC1_Config(void
){ DAC_InitTypeDef DAC_INIT; DMA_InitTypeDef DMA_INIT; DAC_INIT.DAC_Trigger
=DAC_Trigger_T6_TRGO; DAC_INIT.DAC_WaveGeneration
=DAC_WaveGeneration_None; DAC_INIT.DAC_OutputBuffer
=DAC_OutputBuffer_Enable; DAC_Init(DAC_Channel_1,
&DAC_INIT); DMA_DeInit(DMA1_Stream5); DMA_INIT.DMA_Channel
=DMA_Channel_7; DMA_INIT.DMA_PeripheralBaseAddr
=(uint32_t)DAC_DHR12R1_ADDR; DMA_INIT.DMA_Memory0BaseAddr
= (uint32_t)&function; DMA_INIT.DMA_DIR
=DMA_DIR_MemoryToPeripheral; DMA_INIT.DMA_BufferSize
=SINE_RES; DMA_INIT.DMA_PeripheralInc
=DMA_PeripheralInc_Disable; DMA_INIT.DMA_MemoryInc
=DMA_MemoryInc_Enable; DMA_INIT.DMA_PeripheralDataSize
=DMA_PeripheralDataSize_HalfWord; DMA_INIT.DMA_MemoryDataSize
=DMA_MemoryDataSize_HalfWord; DMA_INIT.DMA_Mode
=DMA_Mode_Circular; DMA_INIT.DMA_Priority
=DMA_Priority_High; DMA_INIT.DMA_FIFOMode
=DMA_FIFOMode_Disable; DMA_INIT.DMA_FIFOThreshold
=DMA_FIFOThreshold_HalfFull; DMA_INIT.DMA_MemoryBurst
=DMA_MemoryBurst_Single; DMA_INIT.DMA_PeripheralBurst
=DMA_PeripheralBurst_Single; DMA_Init(DMA1_Stream5,
&DMA_INIT); DMA_Cmd(DMA1_Stream5, ENABLE); DAC_Cmd(DAC_Channel_1, ENABLE); DAC_DMACmd(DAC_Channel_1, ENABLE);}
#timer-trigger #static2016-05-10 3:55 AM
The code as presented is nearly unreadable, please use the Format Code Block option. The Paintbrush [{}] icon.
The static directive shouldn't make.a difference to the functions in this context. What compiler are you using? Have you single stepped the code in a debugger to better understand what is going on.2016-05-10 5:03 AM
#include <
stm32f4xx.h
#define OUT_FREQ 5000 // Output waveform frequency
#define SINE_RES 128 // Waveform resolution
#define DAC_DHR12R1_ADDR 0x40007408 // DMA writes into this reg on every request
#define CNT_FREQ 42000000 // TIM6 counter clock (prescaled APB1)
#define TIM_PERIOD ((CNT_FREQ)/((SINE_RES)*(OUT_FREQ))) // Autoreload reg value
const uint16_t function[SINE_RES] = { 2048, 2145, 2242, 2339, 2435, 2530, 2624, 2717, 2808, 2897,
2984, 3069, 3151, 3230, 3307, 3381, 3451, 3518, 3581, 3640,
3696, 3748, 3795, 3838, 3877, 3911, 3941, 3966, 3986, 4002,
4013, 4019, 4020, 4016, 4008, 3995, 3977, 3954, 3926, 3894,
3858, 3817, 3772, 3722, 3669, 3611, 3550, 3485, 3416, 3344,
3269, 3191, 3110, 3027, 2941, 2853, 2763, 2671, 2578, 2483,
2387, 2291, 2194, 2096, 1999, 1901, 1804, 1708, 1612, 1517,
1424, 1332, 1242, 1154, 1068, 985, 904, 826, 751, 679,
610, 545, 484, 426, 373, 323, 278, 237, 201, 169,
141, 118, 100, 87, 79, 75, 76, 82, 93, 109,
129, 154, 184, 218, 257, 300, 347, 399, 455, 514,
577, 644, 714, 788, 865, 944, 1026, 1111, 1198, 1287,
1378, 1471, 1565, 1660, 1756, 1853, 1950, 2047 };
static void TIM6_Config(void);
static void DAC1_Config(void);
int main()
gpio_A.GPIO_Pin = GPIO_Pin_4;
gpio_A.GPIO_Mode = GPIO_Mode_AN;
gpio_A.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &gpio_A);
TIM6_Config();
DAC1_Config();
while (1)
TIM_TimeBaseStructInit(&TIM6_TimeBase);
TIM6_TimeBase.TIM_Period = (uint16_t)TIM_PERIOD;
TIM6_TimeBase.TIM_Prescaler = 0;
TIM6_TimeBase.TIM_ClockDivision = 0;
TIM6_TimeBase.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM6, &TIM6_TimeBase);
DAC_INIT.DAC_Trigger = DAC_Trigger_T6_TRGO;
DAC_INIT.DAC_WaveGeneration = DAC_WaveGeneration_None;
DAC_INIT.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
DAC_Init(DAC_Channel_1, &DAC_INIT);
DMA_INIT.DMA_Channel = DMA_Channel_7;
DMA_INIT.DMA_PeripheralBaseAddr = (uint32_t)DAC_DHR12R1_ADDR;
DMA_INIT.DMA_Memory0BaseAddr = (uint32_t)&function;
DMA_INIT.DMA_DIR = DMA_DIR_MemoryToPeripheral;
DMA_INIT.DMA_BufferSize = SINE_RES;
DMA_INIT.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_INIT.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_INIT.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_INIT.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_INIT.DMA_Mode = DMA_Mode_Circular;
DMA_INIT.DMA_Priority = DMA_Priority_High;
DMA_INIT.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_INIT.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_INIT.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_INIT.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA1_Stream5, &DMA_INIT);
Sorry for my deficiency !!!
2016-05-10 5:07 AM
2016-05-10 5:43 AM
Nothing is really jumping out, any linker errors?
Try this#include <
stm32f4xx.h
int main()
GPIO_InitTypeDef gpio_A = { 0 };
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_DMA1, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC | RCC_APB1Periph_TIM6, ENABLE);
TIM6_Config();
DAC1_Config();
while(1)
TIM6_TimeBase.TIM_Period = (uint16_t)(TIM_PERIOD - 1); // 0 .. N-1
DAC_InitTypeDef DAC_INIT = { 0 };
DMA_InitTypeDef DMA_INIT = { 0 };
DMA_INIT.DMA_Memory0BaseAddr = (uint32_t)&function[0];
2016-05-10 6:08 AM
thanks for your suicide. I am going to test your code in tomorrow because i don't have any oscilloscope in my home.:).
2016-05-10 7:19 PM
I was test your code and the result is correct. I received sine wave on my oscilloscope. but I don't understand why I did wrong. Can you tell me abotut that?
2016-05-10 7:40 PM
And why I need to set first value for
