2016-02-24 12:16 AM
Hi:
I use uVision 5.11.1.0, which does not contain new body ''STM32F469''. I try to use ''pack installer-> packs->check for updates
'' to update database, but it failed with following message, from Keil's website, I know it's compatible problem, I don't want to upgrade uVision because we have some projects already used current version uVision. Is there any way (may manually edit some files) to add new device (STM32F469) to the database?Reading one or more Pack descriptions failed:
C:\Keil_v5\ARM\PACK\.Web\ABOV.CM3_DFP.pdsc
C:\Keil_v5\ARM\PACK\.Web\AmbiqMicro.Apollo_DFP.pdsc
2016-02-24 7:50 AM
Hi Calvin63,
Try to download and install the software pack directly from this link -Syrine-2016-02-24 4:40 PM
Hi Syrine:
I download it directly and installed. But now every time uVision start, it report errors and showed a dialog:Error loading software packs
Run-Time Environment might work incorrectly
See Build Output for details. The Build output is:
C:\Keil_v5\ARM\PACK\Keil\STM32F4xx_DFP\2.7.0\Keil.STM32F4xx_DFP.pdsc(3666,19):
Error parsing node '#text' :no declaration found for element 'workingDir'
C:\Keil_v5\ARM\PACK\Keil\STM32F4xx_DFP\2.7.0\Keil.STM32F4xx_DFP.pdsc(3667,18):
Error parsing node '#text' :no declaration found for element 'arguments'
C:\Keil_v5\ARM\PACK\Keil\STM32F4xx_DFP\2.7.0\Keil.STM32F4xx_DFP.pdsc(3676,60):
Error parsing node '#text' :no declaration found for element 'gpdsc'
Error parsing node '#text' :attribute 'name' is not declared for element 'gpdsc'
C:\Keil_v5\ARM\PACK\Keil\STM32F4xx_DFP\2.7.0\Keil.STM32F4xx_DFP.pdsc(3677,17):
Error parsing node '#text' :element 'workingDir' is not allowed for content model 'All(description,select,command,project_files,files,extensions)'
C:\Keil_v5\ARM\PACK\Keil\STM32F4xx_DFP\2.7.0\Keil.STM32F4xx_DFP.pdsc(3792,141):
Error parsing node '#text' :attribute 'generator' is not declared for element 'component' So what I can do now? I find the new STM32F4xx_DFP version is 2.7.0, old one (now still stay in folder) is 1.0.8. How can I ask uVision to use old 1.0.8 or how to uninstall 2.7.0?
2016-02-24 4:50 PM
Hi Syrine:
2016-02-25 2:49 AM
install new Keil version in to new location, both will work
2016-02-25 4:53 PM
Hi:
I know update the newest version is the best solution to solve the problem, however there are many things I should to do if update to new version uVision, I need to guarantee many things go right after update. so I prefer many things the same, just modify database.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
