2015-05-09 10:08 PM
I crate a project with stm32cube
my chip is stm32f103zc i enable fsmc for lcd interface and 16 bit data address and A0 for register select . this function HAL_SRAM_Read_16b(&hsram1,&send_address,send_buffer,10); do not work. I see all pin in oscope and do not change any pin. why?2015-05-10 5:07 AM
Would suggest you try to access the memory behind the FSMC directly.
If that also fails, check the clocks, GPIO and AF settings (registers), along with those of the FSMC peripheral. That might enlighten you to where the problem lies, and if it's a problem ST needs to fix.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
