2014-11-06 2:45 AM
Hello! I am trying to load a VCP example code to my STM32F303 Discovery board, but i get error: Flash loader: Failed to setup call to 'flash init'. I am using EWARM. Maybe someone knows the solution to this error.
#stm32f3032014-11-06 6:20 AM
Are you sure that you checked ''use flash loader(s)'' under Project options->Debugger->downloads?
2014-11-07 3:39 AM
same apply are you correctly set SWD/JTAG ?
usually as default it uses JTAGWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
