2008-06-18 2:05 AM
file system support
2011-05-17 3:37 AM
Quote:
I need to work on files ... I wonder if i need to add file system support to get this working.
Yes, of course you will need a file system in order to work with files! 8-)2011-05-17 3:37 AM
I am trying to run some benchmark embedded code on stm32-performance stick board (from Hitex). The compiler is Altium/Tasking VX toolset. I need to work on files (mostly ''fread''). Whenever i try to open a file fopen fails. I wonder if i need to add file system support to get this working. I have checked the other ARM forums on ST web site and they have discussed same problem and looks like it should work. But it is not. Any body faced similar problem? Help appreciated. thanks HemalWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
