2014-10-17 2:56 PM
I am using an STM32F4 discovery board. I want to use an external trigger to generate an interrupt that will cause a pulse stream. I have found examples using an external trigger for one pulse mode as well as output compare examples that generate pulses. I am struggling to figure out how combine these two concepts....
2014-10-17 3:56 PM
TIM1 and 8 should allow multiple pulse trains with PWM and Repetition Count (8-bit), ie frequency, duty, and cycles
