2017-01-29 8:22 AM
The attached project is made up of CubeMX 4.18.0.
If you open the project after opening the project at CubeMX 4.19.0 and then creating source again, an error occurs.
2017-02-01 3:21 AM
This is a known issue with MX 4.18.
Please use the import feature in MX 4.19:
Start by creating a new project, selecting the STM32F103C8Tx MCU (as used in your 4.18 project),
then select the menu File > import to import your 4.18 ioc file.
You will need to redo the clock tree configuration that could not be automatically imported.
But, project generation will work fine then.
2017-01-29 12:46 PM
Hi
SoHaeng.Lee
,I will check this issue and come back to you as soon as possible.
Imen
2017-02-01 3:21 AM
