2016-05-19 12:00 AM
Dear all ST staffs,
I found a bug about clock configuration for F429-NUCLEO in cubeMX. I want you to fix this problem.
To reproduce the bug, please make a new F429-NUCLEO project, and choose HSI as clock source. The frequency value of HSI at CubeMX is 8 MHz, but datasheet says it is 16 MHz.I hope my contribution will help you.
Best regards, Fumihiko.2016-05-19 4:10 AM
Hi nimura.fumihiko,
Thanks dor the feedback and contribution. I will report this to our CubeMx team for check. -Hannibal-2016-05-24 1:48 AM
Dear user,
Thank you for reporting this issue. It will be fixed in a next release. As a workaround you can manually change the HSI frequency value in the .ioc file: RCC.HSI_VALUE=16000000 Best regardsWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
