2013-04-19 2:04 AM
For my tests, i use a STM32F0 discovery and i download on the ST website, theEEPROM emulation in STM32F0xx microcontrollers
software.http://www.st.com/web/en/catalog/tools/PF258153
When i run this demo project with �Vision 4, the execution of this sofware causes a crash of my debug session. I remark that the crashhappens when
the loop
is used to write
the data
is
larger than the
page size
. But when i execute the same software in step by step, no crash happens ! I suppose that a timing problem. Can you help me ? #stm32f0-eeprom-emulation-bug #forum-says-no2013-04-25 2:37 AM
up
2013-04-25 2:51 AM
Crashes how exactly, and on what instruction? You provide no code/process to demonstrate the failure. Does it fail every time? The first time? When you run it a dozen times, or modify it?
Before kicking posts, consider why they are being ignored.2013-04-25 7:02 AM
I found alone !!!
FLASH_SetLatency(); !!! Steps for reproduce this bug: - Buy the F0 Discovery board - Download the exempleEEPROM emulation in STM32F0xx microcontrollers
(http://www.st.com/web/en/catalog/tools/PF258153
) - Load - Run - Crash !!!It
is clear
this time?
2013-04-25 8:14 AM
- Buy the F0 Discovery board sure, I'll run out and spend some money to help you for free
Crashes how exactly, and on what instruction? You still provide no code/process to demonstrate the failure. Does it fail every time? The first time?
anyhow, I have a good guess. you forget that flash is page based and using some ''EEPROM bytes'' in a page that contains code, of course, makes that page erase. Erik
2013-04-25 9:14 AM
It
is clear
this time?
Not much frankly, does it output a message saying ''Crash!!!'', or can you figure out where it is by stopping the CPU in the debugger? Does it get stuck in a loop, the Hard Fault handler? Other useful information might be what tool chain you're using?
2015-09-04 12:25 AM
Hi, ST sirs,
I also have the write data eeprom will ''crash'' problem, I found that when the value of data = 0x00, the system will crash.Is that need spacial process when data value = 0x00.By the way, why the data eeprom need erase process?When will the data eeprom need be erase?I just do the read and write procedure. Thank you. KevinWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
