2008-01-29 7:29 PM
cortex flash erasing
2011-05-17 3:22 AM
I'm using Crossworks with segger j-link. I have a problem to erase flash where the downloader writes the application code. I try to erase it also manually (with 'erase all' command) but it is not erased. Is there any one that know a solution ??? Thanks.2011-05-17 3:22 AM
works fine with crossworks and jlink, check you have the latest versions of both installed.
Cheers SpenWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
