2020-03-25 12:41 PM
I am working on stm32f429 and micro controller reset every 500 ms, iwdg is not active but, it seems, it is activated by hardware or something which force cpu reset.
How can i get rid of this?
Please help,
BR,
2020-04-05 5:07 AM
Apparently hardware watchdog in all M4 controllers are activated by default in optional byte ...
Thanks for replying... problem is solved.
2020-03-25 12:51 PM
Diagnose the underlying problem?
Scope the NRST pin, the VCAP and VDDA supply pins.
Check for external sources connected or sharing the NRST
Does the problem occur with a simple LED Blinky program?
Is this something that started occurring recently, with specific new code or function?
ST-LINK? DISCO/NUCLEO board? Your own?
2020-03-25 3:14 PM
Why do you think this? Did you look at IWDG registers? If so, they don't set themselves. Something in your code is, so find it.
2020-04-05 5:07 AM
