2017-06-22 11:07 AM
Using System Workbench and targeting a Nucleo-F411RE. Set JP5 on the Nucleo board and routed 5V to CN2 to the correct header position. Grabbed the SOUNDTER1 package and programmed the board. Not getting any output.
I noted that the project was for a F401RE, and went through generating the initialization code for both the '01 and the '11. All I really observed was a change in clock and flash latency.
Is there something else that I'm missing? Better yet, is there a good outline for what should be changed in the source to switch between either processor in System Workbench?
