2015-10-16 5:15 AM
When using Cube MX to generate initial code for general timer,the initial code does not set TIMx_CR1 register CEN bit and TIMx_DIER register UIE bit.So it is unable to go into timer overflow interrupt.
2015-10-16 6:32 PM
You may do it in Timer configuration NVIC Setting. (like in Attachments) ________________ Attachments : NVIC.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hth1&d=%2Fa%2F0X0000000aVp%2FUNU054uz_cYlBO1jzu65IzmDTXxOFUxTHnwjmisgl78&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
