Problem reading the counter/timer register TIM->CNT
Posted on September 21, 2012 at 21:20STM32F407: I use Timer2-5 in QEI configuration, and in my motor control loop (coming every 45usec) I need to read out the current position from TIM->CNT. If I scan the values read out - it is strange that about e...
flyer31 by Senior
  • 707 Views
Atomic Operation
Posted on September 18, 2012 at 21:20Hi, as i know stm32 operations alway read-modify-write. Not atomic. If i read below it looks like C is already atomic for some operations. Or is it not guarantee on stm32 platform? http://www.informit.com/guides/...
STM32F103 GPIO Output Speed
Posted on September 21, 2012 at 15:07When I program a GPIO pin, I have to define a ''speed'': 2, 10 or 50MHz. What does this mean in terms of hardware? Is this a filter? If I program the pin with 2MHz I can't output a signal with 5MHz. What is the h...
jpb by Associate
  • 1097 Views
Output voltage problem with ST802RT1A
Posted on September 18, 2012 at 17:34Hi thereI am using the Ethernet Transceiver ST802RT1A to make my own PCB board following the design of STEVAL-PCC012V1 (http://www.st.com/internet/evalboard/product/250577.jsp) except one thing - I changed the ma...
jinkang by Associate II
  • 2656 Views
STM32F407 TIM2_CH1
Posted on September 20, 2012 at 20:07Hi, Looking at the data sheet of the STM32F407X, I can't find what pin number the TIM2_CH1 maps to. Please help. Thanks Nhan Pham
npham by Associate II
  • 1861 Views
DCMI, SDIO and USART
Posted on September 20, 2012 at 12:05there have been lots of posts on dcmi. but I couldnt find what I wanted on any of them.i have a STM3240-G eval board with ov2640 camera. I am getting pictures at 320x240. I store it in the SRAM and transfer it to...
nakulrao by Associate II
  • 710 Views
Can't get simple blinkylights to work
Posted on September 20, 2012 at 01:42 After figuring out how to configure ARM GCC and Eclipse, I wrote the shortest demo program I could come up with. My program is supposed to light one LED when the user button is pressed, and the other LED whe...
How to upgrade the firmware via GPRS
Posted on September 19, 2012 at 14:33I have designed a GPRS Modem. STM32F103R8 has been used in it. After realizing tis project, upgrading firmware from a web server was requested. In my circuit there is a Flash Memory (M25P16). This memory communic...
sbaris by Associate
  • 1851 Views
