STM32F051 IAP w/o a pushbutton
Posted on August 15, 2013 at 21:45Hi,We are developing a product using a STM32F051 and want to be able to upgrade the code using IAP. I've been reading anything I can find, AN4065, the examples, etc. It seems like the general idea is that the micro ...
munger by Associate II
  • 1321 Views
ADC with STM32F303VC
Posted on August 19, 2013 at 07:48I want read ADC of STM32F303VC then display status  on three LED (If ADC>1000 LED red bright,ADC<500 LED green bright and extant LED ogrange bright) programmed code below,but i don't find error.Thanks everyone!#incl...
bee by Associate II
  • 2321 Views
Missing doc on STM32l100 flash/eeprom programming?
Posted on August 20, 2013 at 12:11Hi everyone, I'm currently developing a product based on a stm32l100r8 mcu. I'm unable to find a document (akin to pm0062 for stml152) about flash/eeprom programming for this chip. Is this document available somewhe...
STM32L_Discovery Blinking LEDS
Posted on August 21, 2013 at 09:12I have an STM32L-Discovery Board, I found this program compiled it and loaded it on my board but nothing happens.  What am I miising..  Thanks in Advanced. CM.GPIO_InitTypeDef (GPIO_InitStructure); int main() { GPIO...
STM32F103 TIM3 Timebase problem?
Posted on August 21, 2013 at 16:41My timebase for TIM3 does seem to obey the laws of timebase calculation! I think I've had this problem before, what am I doing wrong.TIMCLK = 36MHz  TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;  /* TIM3 clock enab...
kkarasti by Associate II
  • 3144 Views
Change IWDG reload and prescaler live
Posted on June 07, 2013 at 17:32Following my last post on the subject of flash memory erase vs watchdog I have another concern.Reading the spec I believe that I may be able to change the prescaler+reload of my watchdog just for the time that the fla...
timer 2 and its channel
Posted on August 20, 2013 at 16:57Hello,I am working for 6 months with the Timer 2 of a STM32L15x.I use the channel 2 to capture the timer value; The pin used is PB3.My application is working fine.Now, for an hardware problematic, I need to use the ...
gfoujanet by Associate II
  • 2406 Views
USB_OTG_FS on the STM3240G-EVAL?
Posted on August 21, 2013 at 01:04I can't get USB_OTG_FS communication to work on the STM3240G-EVAL board. USB_OTG_HS works with no problem. I tried disabling HS using JP31, but ST's example application still can't reach the USB_OTG_FS.I thought thi...
mattscar by Associate II
  • 1444 Views
Bit Band access to AHB2 Peripherals on STM32F373
Posted on August 20, 2013 at 17:12 Hello, I am trying to access GPIOB registers on STM32F373 using bit banding memory access. Per the documentation, all the peripheral registers are mapped to bid-band memory locations. While it is easy to ...
omri by Associate
  • 1845 Views
STM32L152 ADC DMA restart question
Posted on August 20, 2013 at 17:35 Hi, I'm trying to implement ADC multichannel scan (single sampling) with DMA on STM32L152 but there's a problem with conversions start. First SW conversion start takes the samples but following start com...
